97 corolla check engine light on - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-19-2005, 03:00 PM   #1 (permalink)
GKK
View GKK's Photo Gallery
My sons 97 Corolla was running very smooth until I replaced the air filter with a K&N. A day later the check engine light came on and the engine (1.8L) started to idle rough.
I was going to clean the MAF sensor but, found that the 97's didn't have one.
I have installed K&N air filters in all of my other vehicles with no problems. I appreciate all suggestions and advice. Thank you for your help.
GKK is offline   Reply With Quote
Old 09-20-2005, 02:10 PM   #2 (permalink)
GKK
Update:
Today, I went to AutoZone and borrowed their code reader. There was only one code which was P0304 (cylinder 4 misfire).
I'm going to replace the spark plugs and wires but, could there be something else causing the cylinder 4 misfire. Thanks
"97" Corolla DX, Automatic, K&N air filter, Kumho tires, Mobil One Synthetic oil and oil filter.
Old 09-21-2005, 12:33 AM   #3 (permalink)
The Mad Scientist
View Dr Tweak's Photo Gallery
There could be. Try that first and see what happens.
-Doc
-Dr Tweak, Toyota engine swap wiring expert extraordinaire
Check out some of the swaps I've done at http://www.phoenixtuning.com/swaps.html
Dr Tweak is offline   Reply With Quote
Old 09-21-2005, 12:53 PM   #4 (permalink)
GKK
Thanks, unfortunately my the car was stolen form my driveway this morning.
Old 09-21-2005, 11:39 PM   #5 (permalink)
Jozer
View Team High Rev's Photo Gallery
did you get the car bck, and my light turns on too, all you do is disconnect the batery and it should restart the ecu, when you put an upgrade you should always restart it, because the ecu doesnt know what it has so when you restart it it can read it
Team High Rev is offline   Reply With Quote
Old 09-22-2005, 02:32 AM   #6 (permalink)
GKK
Unfortunately I didn't get the car back yet. Also, I disconnected the negative battery terminal which cleared the code but, the check engine light always reappeared and the engine had a slight studder.
At least the thief got a car that wasn't running 100% yet.
