Here she is, now anybody will be able to upgrade 1/4 of their stock stereo system! I will be doing left speaker and gauge cluster in due time, so everyone that may be needing these, hold tight.
The Glovebox/Speaker
Pry off the speaker grill.
Grill Removed
Remove the two screws on the bottom-right of the assembly.
Remove the two screws on the bottom-left of the assembly.
Open the glovebox and remove all of these screws:
Pry off the left screw cover & remove it.
Pry off the right screw cover & remove it.
Remove the screw behind the speaker grill.
Unscrew the glovebox.
Remove the assembly
The glovebox removed.
Disconnect the speaker wire. (Kappas hehe...)
Remove the nuts from the back of the speaker box.
Remove the speaker box.
Unscrew & Remove the speaker from the box.
And there you have it, hope this helps! (and maybe this and my other DIY should be sticky-ed?)
