Keeps running after I shut if off? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-22-2005, 03:23 PM   #1 (permalink)
omg jdm
aaron7's Avatar
View aaron7's Photo Gallery
When I shut my car off (89 SR5 4af) it keeps running a little then dies. JUST LIKE IN THE MOVIES!! What the heck is wrong?
89 MR2 MK1.5 - endless project. shiny, check. fast... almost installed...
74 CB360 - Lots of cool cafe stuff
98 Jeep GC 5.9 - Mopar intake, Mopar ECU, H&R springs, a/d/s speakers & amps, 3 JL W3
aaron7 is offline   Reply With Quote
Old 09-22-2005, 03:30 PM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Either its running lean or the fuel cut solenoid in the carb isnt working.
Old 09-22-2005, 03:39 PM   #3 (permalink)
omg jdm
aaron7's Avatar
Fuel cut solenoid? Where is that located? Also, thanks for noticing that I had a carb and not fuel injection! So many people argue with me and tell me I don't have a carb lol
Also, if I was running too lean, what might I be able to do to fix that?
Old 09-22-2005, 03:58 PM   #4 (permalink)
Pow! Right in the Kisser!
Liter's Avatar
View Liter's Photo Gallery
I get the same thing with mine....i turn off the car and it sputters then shuts off. What i found was causing it was for some odd reason whenever it came near my time to get a oil change it would start. After i change the oil, it doesnt do it again for another 5k.
Liter is offline   Reply With Quote
Old 09-22-2005, 05:02 PM   #5 (permalink)
Foul Weather Drifter
View SpeedballTrix's Photo Gallery
Maybe you have a secret turbo timer in there somewhere
Or maybe it's what flash said =P
SpeedballTrix is offline   Reply With Quote
Old 09-22-2005, 10:01 PM   #6 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
your throttle plate is open too far, whats happening here is when you shut it off, the plug electrodes are hot enough to keep the motor going without a spark, the problem keeps going when the motor is able to pull enough air past the plates and get enough gas from the idle circuit in the carb and off it goes. open the plates some more and put it in gear and it just might take you somewhere, simply slow the idle down and dont run the idle very rich and it will behave
Old 09-23-2005, 08:16 AM   #7 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $273221
View REN69's Photo Gallery
Gotta love carbed cars..
Old 09-26-2005, 04:08 AM   #8 (permalink)
ZXT
View ZXT's Photo Gallery
fred and flash explanation got some points. I experienced this first hand and I already heard what flash and fred said but it turns out my "dieseling" problem causes by improper (high idling) on my 4AF. I tinker with my A&F mixture at first, making sure it was set properly, then adjusted my idling without aircon to 750 rpm, adjusted with aircon at 900 rpm and finally set my timing to 10 degrees (which was at 5 degrees before).
Problem solved. Engine dies the moment I turn the key.
Just a suggestion.
Just cruising...on my stock AE92
F1 Club of the Philippines
ZXT is offline   Reply With Quote
Old 09-26-2005, 05:41 AM   #9 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
i could have sworn thats what i said?
