disabling drl's on 2006 type s corolla - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-23-2005, 08:58 AM   #1 (permalink)
View tommy13's Photo Gallery
does anyone know which wire to cut to disable the drl's on the 2006 models i found the box under the steering column and have cut the yellow wire but that disable the headlights all together i couldnt used the manual switch to turn on the lights do i have to ground the other end for it to work manually please help all i did was cut the yellow wire to test it.
tommy13 is offline   Reply With Quote
Old 09-23-2005, 09:35 AM   #2 (permalink)
NRM
NRM's Avatar
View NRM's Photo Gallery
Worst comes to worst, you should have taped / crimped the wire back together.
There are two yellow wires under the dash, one of them will disable the DRLs. Send it to a ground under the dash and you should be done.
NRM is offline   Reply With Quote
Old 09-23-2005, 10:05 AM   #3 (permalink)
thanks for the reply i will ground the other end to see if that works.
Old 09-23-2005, 10:54 AM   #4 (permalink)
View polo708's Photo Gallery
ground the end that comes out of the box... then it will work.
2004 Supercharged Corolla S
polo708 is offline   Reply With Quote
