I've copied this from an earlier post....
Here is my problem.
My truck runs like ass when its cold. I got the AAP replaced 2 times, 3 diff. people have worked on it to no avail. If I get into is, start up, and try to drive it cold, it will chug, surge, and stumble until I turn it off, go into school for 5 hours, then come out in the hot day and start it, where it runs fine. Also, if I leave to idle for about 10 mins in the morning instead of just getting in a driving off, it runs fine. What is my problem, I don't think I have any vaccum leaks, checked the fluids, fuel mix is good, and it runs fine when its hot. Even if it gets to operating temp while running it WITHOUT a 10 min warm up in the morning, it runs like crap. But, again, in the afternoon or after 10 mins of idle, it runs fine at any temp. WTF is wrong with my truck. Distributor? Carb? I'm at my wits end. HELP
with 3 people already looking at it, that should have narrowed it down a bit.....hopefully at least one of them started with a tune-up, ie. new plugs, cap, rotor, plug leads, all filters, etc. Most all people do not really maintain there vehicles that good, and when something F____ Up figure you can just change a single part to fix it. While this is possible, a good mechanic will start with a common tune-up and go from there......
...it turned out to be his distributor cap, but you get the jest of it...and remember to change the fuel filter.
