So my 4A-F project has progressed further. Who would of figured that someone would put a programmable ignition with launch control onto the machine. However, to make this project go further, a more adjustable ignition has to be installed.
The distributor cap has been modified. Theres really nothing inside it except a hall shutterdisk, a hall sensor and the rotor. The only duty to the distributor cap is to distribute the spark and use the hall sensor to give refrence points to the ignition box.
Heres the homepage for the product I'm using, a locally made ignition controller,
http://www.vpv-motorracing.com/thunderen.htm
Then some project pics:
Bosch high voltage ignition coil, and the modded distributor
Launch control trigger, and the led next to the trigger is the shiftlight
Closeup of the modified distributor cap
