I can't explain it either, but it seems that when I used the 5w40 from IGOL Symbol Ceramic Line(you can check their site) the engine sounded smoother, less valve noise and the pick up is peppier, I don't know, could it be the formula in the IGOL Symbol Ceramic 5w40 is different than their IGOL Process Compact 5w30? The oil line is different, the IGOL Symbol Ceramic is above the IGOL Process Compact line(both are full synthetics).
Postscript to that, I noticed also that the IGOL Symbol Ceramic 5w40 doesn't get darker as fast as the 5w30, come to think of it, it stays clearer much much longer. Could it be that there's less detergency in the 5w40 than the 5w30, similar to that of a racing oil that contains less detergency than street oil.
My question is, is it ok to use full synthetic 5w40 eventhough the manaul only recommends 5w30 or 10w30?
I want to use the 5w40, will this be ok?
