Fuse problem??? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-27-2005, 11:25 PM   #1 (permalink)
View taz d's Photo Gallery
AE92 Fuse problem???
I seem to be having a problem with a fuse on my 91 corolla. The fuse for the gas and temperature gauges keeps on burning out. It burns out and I replace it. I turn on my car and it works, but when I remove the parking brake and shift it into "D" it burns out. It has been doing this very frequently. What could be causing this problem??
taz d is offline   Reply With Quote
Old 09-27-2005, 11:26 PM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
You have a short circuit somewhere.
Old 09-27-2005, 11:30 PM   #3 (permalink)
where could this short circuit be? any probable place?
Old 10-02-2005, 02:58 PM   #4 (permalink)
How could i find out where this short circuit is? I figured out that it does it when I take it off park.... either to put it in reverse or drive...
Old 10-02-2005, 03:18 PM   #5 (permalink)
Resident asshole
Flashmn's Avatar
I cant say via internet where it could be.
Old 10-02-2005, 04:27 PM   #6 (permalink)
how would I go about finding it myself? is it hard to do so?
Old 10-02-2005, 11:19 PM   #7 (permalink)
Resident asshole
Flashmn's Avatar
Finding the cause first, then trial and error seeing which wire gets hotter than the others. Not easy thats for sure.
Old 10-03-2005, 04:04 AM   #8 (permalink)
View karazy's Photo Gallery
The easiest way is to disconnect the battery and do a continuity check at the fuse box. The line that it is shorting with will probably have a higher rated fuse than the one that keeps blowing. Once you find the guilty system, it shouldn't be to hard to find the short, unless it is behind the dash.
karazy is offline   Reply With Quote
Old 10-03-2005, 11:31 AM   #9 (permalink)
foodaa's Avatar
View foodaa's Photo Gallery
Did you do some work on the car before it started blowing fuses? Or did it just do that for no reason?
foodaa is offline   Reply With Quote
