I've lost first, Manual swap? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-28-2005, 06:29 AM   #1 (permalink)
View Damemorder's Photo Gallery
Is it possible? I prefer manual... I bet it would be better to find a local parts car due to the sheer number of small parts, but how extensive is it? Just pedals, cables and hydraulic lines right?
'90 Geo Prizm AE92, 4A-FE, Auto 189K miles | Spray painted headliner | DuraStop pads/shoes | Dual Cathode trunk light | Durabrand CD | Shaved badges and molding
'93 Light Beige Metallic Bonneville SE 187K miles | Disassembled for rebirth
Damemorder is offline   Reply With Quote
Old 09-29-2005, 10:47 PM   #2 (permalink)
The TN Member
View punter's Photo Gallery
Its not to hard to do if your handy with a spanner, its tracking down all the parts which can be hard/expensive.
You will need
gearbox with bellhousing (duh)
Flywheel (with correct bolts, Flexplate ones are often too short)
Clutch
Clutch lines and cylinders
pedals
and you'll need to do a little wiring to fool you computer ( ie auto's only start in park)
finding a donnor car is often easiest and may work out cheaper
ROB
punter is offline   Reply With Quote
Old 09-30-2005, 02:37 PM   #3 (permalink)
Sweet n' Lowdown
BLUEMEANIE's Avatar
Gameroom cash: $114450
iTrader Score: 9 reviews
View BLUEMEANIE's Photo Gallery
anyone know what wiring needs to be done to fool the the 7AFE ecu ?
06 NB tC - OG Team HAMSTER - SUPERCHARGED
BLUEMEANIE is offline   Reply With Quote
Old 09-30-2005, 10:01 PM   #4 (permalink)
Does anyone know if a Corolla will work? I'm not concerned about the interior panels, as long as they are close enough for me to fabricate.
I found an '89 Corolla, But no Manual Geo's of any year.
Old 09-30-2005, 11:01 PM   #5 (permalink)
The Mad Scientist
View Dr Tweak's Photo Gallery
Dameorder, yes, the parts from a Corolla will work. Also remember that you will want the brake pedal from a 5-speed (or cut yours down), shifter assembly and cables, master and slave cylinder, and the driver's side mount which is different on the 5-speeds.
BLUEMEANIE, there are two wiring issues to worry about. The first is the neutral start switch, basically that needs to be ran over to the clutch start switch which replaces it on the 5-speed, and also the ECU may get upset when it doesn't get a signal from the auto tranny and throw a CEL. In that case some resistors will need to be wired in, or a 5-speed ECU sourced.
-Doc
-Dr Tweak, Toyota engine swap wiring expert extraordinaire
Check out some of the swaps I've done at http://www.phoenixtuning.com/swaps.html
Dr Tweak is offline   Reply With Quote
