clutch pedal making noise? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-28-2005, 08:46 PM   #1 (permalink)
View rice's Photo Gallery
i have the 94 7afe 5speed, and whenever i press down on the clutch to go into gear, my clutch pedal would have a little squeak coming from it? is this something i should be concern about? is it just getting rusting? it does have about 155,000 miles on it, should i add some kind of grease to it? thanks
rice is offline   Reply With Quote
Old 09-28-2005, 11:17 PM   #2 (permalink)
View burnt03's Photo Gallery
Try greasing the linkage under the dash. If that doesn't do it, the MC might need to be replaced to cure the squeak.
1990 Corolla SR5 (Mine)
2003 Corolla CE (Wife's)
burnt03 is offline   Reply With Quote
Old 09-29-2005, 08:37 AM   #3 (permalink)
Noog
View crockdaddy420's Photo Gallery
I got that problem too, someone told me to grease as well, have not gotten around to it yet. Squeks more on the return, though.
Crizzle Dizzle for Shizzle Bizzle!
Go SOX!!! Yankees you'll soon find out who yo Daddy is Biatch. The yankees bunch a tight wads, don't know how to have fun.
crockdaddy420 is offline   Reply With Quote
Old 09-29-2005, 10:02 PM   #4 (permalink)
RedAE102's Avatar
View RedAE102's Photo Gallery
I had this problem, as well as a slight groan at the bottom of travel coming from the engine compartment (could feel it through the pedal). When I had the clutch replaced, I flushed the clutch fluid and the problem hasn't returned.
'93 Corolla AE102 XLi saloon
We're all looking for something.... Something to be...
RedAE102 is offline   Reply With Quote
Old 09-30-2005, 01:31 PM   #5 (permalink)
Noog
Red you think my clutch, may be going? Can't really tell if it is slipping because I also have a bad cat, and or carb needs some work. If the clutch pedal is squeking is that a sign of a bad clutch. 4af ae92 sedan
