Knocking noise when turning - Toyota Nation Forum : Toyota Car and Truck Forums
Old 09-29-2005, 11:08 PM   #1 (permalink)
View asus's Photo Gallery
Hello, im new to the forum, but i have a problem. My 93 Corolla makes a knocking noise when i take a right turn, or when the car hesitates, "i have a standard" so when i slow down using the gears, and the car shutters back and forth.. it makes the knocking noise..
It started off when the car hesitated like going 20 in first than taking your foot off the gas.. then it started making it more when i turn right.
now i have to go on a trip on Saturday.. so.. any suggestions. .thanks a bunch
asus is offline   Reply With Quote
Old 09-29-2005, 11:13 PM   #2 (permalink)
The TN Member
View punter's Photo Gallery
sounds like an outer CV joint to me
punter is offline   Reply With Quote
Old 09-29-2005, 11:17 PM   #3 (permalink)
View tashirosgt's Photo Gallery
Check you CV joints ("half axles"). Now how to do this? You can inspect and see if the rubber "boots" are cracked. But they can go bad without this happening. If you have jackstands, pu the front of the car up on two jackstands, turn the steering wheel to the right and rotate the tire by hand. See if you hear noise from one of the CV joints. (This is not a perfect test either since your axles are drooping down a little, not in the same position they are in while driving.) While you are at it, check the tihat the tie rod ends are not loose.
tashirosgt is offline   Reply With Quote
Old 09-29-2005, 11:17 PM   #4 (permalink)
im verry sorry.. what is a CV joint... i have no idea how to fix, or work on cars,, i can change my oil ect.. but really.. i want to be able to fix things myself.. i am going to take a corse at college next simester..
how would i look at this or these CV joints..
the noise comes from the Driver side tire.. front..
also.. it almost resinates through the floor of the car.. i was letting my friend drive, and i sat in the back.. and i kina felt it in the floor in the back
Old 09-29-2005, 11:19 PM   #5 (permalink)
ohh.. you guys are fast..
now.. tie rods, is there a diagram somewhere were these parts are labeled so i can see??
my friend kenny has some jack-stands so i will bother him tomorrow to use those..
thanks for the fast replies
Old 09-29-2005, 11:19 PM   #6 (permalink)
Ninja-rator
RningOnFumes's Avatar
Gameroom cash: $398685
View RningOnFumes's Photo Gallery
i concur with punter.
do a search for cv join or axle
depending on how long your trip is, maybe you should have it checked out and fixed?>
umm..to check it your self, you can either turn the wheell and crank the car onto a jack or jack and wheel off.
you are looking for the boot to be torn and depending on how long you've been hearing the clicking, you may or may not have to replace the join
**ADAM! A/C button for Gen 5.5 Camry (2005 LE) !! Por favor!
Brake lights aren't broken, I just don't brake.
--Can honestly go to a parts counter and ask for brake shoes for the front brakes.
--Likes long walks on the beach.... once it's lit by a massive bonfire.
RningOnFumes is offline   Reply With Quote
Old 09-29-2005, 11:27 PM   #7 (permalink)
i dont care what i have to replace .. i just want the car to be safe to drive.. it dont sound like some major problem so thats a relief.. but i will look for thoes suggestions.. and i will post bakc with what i find..
