Air/Fuel ratio guage? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-03-2005, 01:07 PM   #1 (permalink)
View White89SR5's Photo Gallery
I have the Carb 4A-F with a single wire O2 sensor. I was wondering if there is a A/F ratio guage that is compatible with this setup? I really want to install one because I plan pulling the stock jets out of the carb a replace them with something a little more aggresive and I just want to keep an eye on things!!
Hear no evil...Speak no eveil...If you don't bring that s**t around you...You ain't got nothing to worry about!!
http://WWW.MORECASHFLOWNOW.COM
Extra Cash Is Always Good!! Click the link to see how to get it!!
White89SR5 is offline   Reply With Quote
Old 10-03-2005, 01:52 PM   #2 (permalink)
Resident asshole
Flashmn's Avatar
Gameroom cash: $352045
View Flashmn's Photo Gallery
Almost all of them work on the single wire O2 sensor. but if I was you I'd take an EGT meter instead to show the mixture condition.
Old 10-03-2005, 02:04 PM   #3 (permalink)
Snafu's Avatar
View Snafu's Photo Gallery
Narrow band A/F gauges are worthless. Wideband is the only way to go when you're trying to make power.
As far the the EGT gauge, there are so many factors that will affect the readout, but no matter what it is, you should stop when it gets too high. I would get an EGT gauge or a Wideband o2 sensor.
4AFTE running 8psi... 10 psi in the works
Snafu is offline   Reply With Quote
Old 10-03-2005, 02:45 PM   #4 (permalink)
Resident asshole
Flashmn's Avatar
Well, the EGT tells you lot better when you're running lean and when you risk head damage.
Old 10-03-2005, 08:15 PM   #5 (permalink)
Well since I plan on adding more fuel I think my biggest problem would be running to rich so, does the EGT give good readings the rich side of things?
If I run a wideband O2 sensor I am sure that would require wiring it in the the cars Ecu somehow so the computer still gets its info to run correctly. Right? Can a narrow band be effective at all if I don't plan on doing anything extreme just slight changes? Can either of you (or anyone else) recommend guages that are known to give accurate readings?
Old 10-03-2005, 11:29 PM   #6 (permalink)
Resident asshole
Flashmn's Avatar
Cars computer wont read the signal from a wideband.
Old 10-04-2005, 06:59 AM   #7 (permalink)
So won't that effect how the car runs and emmissions?
Old 10-04-2005, 07:50 AM   #8 (permalink)
Resident asshole
Flashmn's Avatar
Your car would put a CEL (maybe) if you put in a wideband o2 sensor.
Old 10-04-2005, 12:03 PM   #9 (permalink)
4Aaron GE's Avatar
View 4Aaron GE's Photo Gallery
Didn't you just say you're running carbs? I'm not sure you even have an ECU.....
What? No animation? Bah.
4Aaron GE is offline   Reply With Quote
Old 10-04-2005, 12:35 PM   #10 (permalink)
Resident asshole
Flashmn's Avatar
Well a basic multimeter would be probably the most accurate measuring device to read the O2 sensor output signal, as it gives out a volt reading.
Old 10-04-2005, 01:16 PM   #11 (permalink)
There is an ECU it does not play as big a role as it would on a Fuel injected car, but it does pick up a signals and sends them to the carb. It was made in the period of time when Toyota was still playing with carbs, but they wanted the effectiviness of fuel injection thats why they finally switch to fuel injection the next model year.
Dude you know what i meant!!
Old 10-04-2005, 01:42 PM   #12 (permalink)
Gameroom cash: $147537
Wideband with analog for stock ECU: http://www.innovatemotorsports.com/products.php
Old 10-04-2005, 02:15 PM   #13 (permalink)
Resident asshole
Flashmn's Avatar
Yes I did, and I said its the most accurate way to read the signal from an O2 sensor. ECU reads the voltage. Those blinking O2 gauges are just a big hassle and it wont tell you what the lambda is reading from the exhaust pipe. put a multimeter in there and you know 100% what the lambda is reading.
Old 10-04-2005, 04:44 PM   #14 (permalink)
View TRDemon's Photo Gallery
AE92 re:
hey guys i did the same setup in my car. using the autometer A/F gauge and a single wire O2 sensor and they work just fine. well my car didn't come with a O2 sensor so i got one for a AE100 corolla and a C.V joint nut and weld it in my exhaust down pipe.
Jayspeed
TRDemon is offline   Reply With Quote
Old 10-04-2005, 05:25 PM   #15 (permalink)
Cool! So which autometer A/F guage did you get and where did you mount it? I was looking at the Sport-Comp series. I found one at Summit Racing for about $52.
