If the trunk opened after you took all the cargo out, the suitcases might have been pushing on something it shouldn't have such as the torsion springs or pinching the bowden cable. Your key should open more than just the driver door. It should open the passenger side door also at the minimum. Do you have a Toyota brand key with the rubber/plastic top portion?
"Valet mode" prevents operation of the trunk lever by the driver. Insert the key and turn CCW until the key is horiontal. This will lock the trunk lid.
2007 Camry 2.4L 5M
