Originally Posted by Webb26
I would think it would be better to drain..then work on what you needed, then refil with brake fluid. Honestly, sythetic would be better, if you rarelt eve change out your fluids. If you do it on a regular basis, you wouldn't give non synthetic time to break down. So really it just depends how often you plain on draining and refilling your brake fluid. But this is only my opinion. BTW who are you getting your brake lines from?
hmm... i guess it stands to reason that if i use synthetic, i probably won't have to change the brake fluid as often. i have already got my brake lines from technafit on the group buy several months ago.
