Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - OhM lOaD
Thread: OhM lOaD
View Single Post
Old 06-27-2003, 05:39 AM   #8 (permalink)
88 LE
Grenaded piston
88 LE's Avatar
View 88 LE's Photo Gallery
Originally posted by Studious
the ohm load must have somin to do with it becuase the 2 ohm hits harder than the 4 but i don't want it if its going to keep blowing out on me, and it was actually a fuse that blew out
How did you wire up the sub?
With 2 ohm dvc (dual voice coil) you can wire it for 1 ohm (parallel) or 4 ohms (series).
With 4 ohm dvc its 2 ohms (parallel) or 8 ohms (series).
So from the specs you gave earlier the 4 ohm dvc wired in parallel would work the best.
"Skoolin' the unlearned!"
