Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - Wiring Harness help!
View Single Post
Old 06-28-2003, 03:02 AM   #9 (permalink)
Stealth
I get angry when Im sober
Stealth's Avatar
View Stealth's Photo Gallery
according to crutchfield, which is correct, im supposed to connect the dimmer negative wire from the harness to the illumination wire on the deck, i did that, works fine
now, however, my battery is being drained too much (90% sure its not cause of connecting the dimmer wire) but because my amp draws too much power (stock alt makes 80 amps, car + deck prob uses about 50, leaving 30 for subs... 30*12=360 watts, my amp is 700 watts). Recently my guages and instrument panel have been dimming randomly, well seemingly randomly, it seems whenever I drive for a bit they'll brighten up to normal but then itll go dim again when i come to a stop or use high beams sometimes.
1995 Silverleaf Metallic Camry LE Automatic beater
1987 Buick Grand National
Stealth is offline   Reply With Quote
