Originally Posted by JayMax03
Even if that is true don't the headlights still dim at a certain volume... I should be getting a custom alternator in two weeks. Hopefully that'll work until then, meanwhile I'm just going to stick with a battery in the trunk and a battery under the hood!
This has been covered several times, typically in discussions about capacitors
It's not the volume, its the current draw from your amps that forces voltage drops, which causes dimming.
The Big 3 and higher output alternators will help, and as discussed before, so will capacitors, to an extent or for certain scenarios. Run the Big 3 first, because its the most cost effective, and if dimming is still an issue, look towards other options.
