Originally Posted by rawknmxpx
$258 is dealer retail for the key. Our dealership doesn't charge to cut keys, however programming a key can cost an hour of labor if it requires a reflash of the ECU (i know the prius is this way...). If it doesn't require an ECU flash I'm pretty sure Toyota has the programming how to in the repair manual (search for orst.edu... GO BEAVERS!) or on a TSB you can get through Tundra Solutions. It's basically a series of open door, turn key, roll up window, grab ankles, count to three, pray it worked to get it programmed.
I couldn't find anything on how to program a key do you have a link?
