Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - 99 Headlights will not shut off
View Single Post
Old 02-07-2007, 12:47 PM   #11 (permalink)
cheesep
View cheesep's Photo Gallery
There are 2 relays on the BACK of the fuse panel under the dash to the left of the steering column. I know that one is for the rear window defogger because mine failed - it stayed stuck on and nearly melted the fuse panel. I know the other one has something to do with lights but I'd have to check my Haynes when I get home tonight to see specifically what it is for.
It will be very challenging to actually see up into there but if you remove the kick panel under the dash below the steering column you can reach up and feel around for it. You may be able to see part of your hand by looking past the front of the fuse panel accessible by pulling out the little change drawer on the left side of the steering wheel. I recall the two relays being mounted horizontally, side by side. They are both the same part number.
Sorry I don't recall which of the two relays does what but you'll know if you've got the right one because it will likely be burnt brown in the middle from being stuck on and overheating.
The way I found out where they were is that I found a 98 rolla at the auto wreckers with the dash torn apart. The little fuse panel was hanging in the air in plain view. I bought those two relays from the wrecker for $2 (total) and have been living happily ever since! (Shallow life).
cheesep is offline   Reply With Quote
