Re: Problem with Tire sensors on 4Runner?
"Anonomouse" <Anonomouse@verizon.net> wrote in message
news:3JWrh.2849$jG1.175@trnddc04...[color=blue]
> Yes, the tire sensor warning light is coming on. Yes, the spare has the
> correct amount of air also.
>[/color]
To answer your original question, yours is the first post I recall reading
regarding a low pressure warning system that uses actual air pressure
sensors. Some systems use the ABS speed sesnors that turn on a light if it
detects a speed differential due to an underinflated tire.
Were the sensors replaced at a Toyota dealership? After the sensors were
replaced, did the system work correctly for a while or did the light come on
right away? I assume that the shop that replaced the sensors offers some
kind of warranty on the repair so you should be able to bring it back if it
is still within the warranty period, which I believe is 12 months/12,000
miles or the balance of the 36 month/36,000 original vehicle warranty,
whichever is longer.
I can only think of 6 things that would make the tire pressure warning light
come on.
1) Tire pressure is low in one or more tires (which you have already
eliminated as a possible cause)
2) The new sensors were not "registered" correctly with the receiver or the
receiver is picking up a signal from another source
3) Something has contaminated one or more of the sensors. Possible
contaminants are moisture in the compressed air used to fill the tire, bead
sealer used to seat the tire bead on the wheel rim, or a fix-a-flat or green
slime product
4) One or more of the sensors is defective
5) There is a problem with the low pressure warning light receiver circuit
or control module.
Ray O
