Re: 2002 Toyota Corolla battery cca range
"Jeff Strickland" <crwlr@verizon.net> wrote in message
news:ZuTsh.5360$U81.727@trnddc06...[color=blue]
> Okay, I can't adress the points about what the CCA should be, or what the
> spec might be.
> But, Ohm's Law says that Voltage, Resistance, and Current are all
> interrelated. And, it goes on to say that Current (watts) and Power (amps)
> are different expressions of the same thing, sorta.[/color]
Current is measured in amperes, power consumed is watts.
[color=blue]
> If the voltage is a constant -- as in the battery circuit -- then the
> power applied to the circuit will lower the voltage as the power goes up.
> Conversely, if the voltage lowers -- as in a battery circuit -- then the
> current will cause the circuit to drop below wha tis needed for proper
> circuit operation.[/color]
Better re-think the logic in this paragraph ;-)
Ray O
