Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - beam produced by DEPO lens
View Single Post
Old 02-14-2007, 11:30 PM   #6 (permalink)
white3ch0c0late
HID/Retrofit Expert
white3ch0c0late's Avatar
View white3ch0c0late's Photo Gallery
HIR bulbs ARE halogen bulbs. And with halogen reflector headlamps, you'll never get a "consistent" beam pattern because of the reflector design and where the light is reflected.
If you get HIDs in stock reflectors, not only will your pattern be worse, but you'll be blinding everyone in sight.
If you want a good, wide, consistent beam pattern, http://www.toyotanation.com/forum/t178884.html buy this, and do a retrofit... and make sure to cover the holes in sides the projector with aluminum so light doesn't leak.
Otherwise, you're stuck.
EDIT: You're getting hot spots with the HIRs because the reflector in your headlamps wasn't designed to reflect that kind of intensity of a bulb.
2009 Audi TT 2.0T --- THE BEAST!
2002 LE 4Cyl --- Gone, but not forgotten. 06/28/09
Glaring blue HID bulbs are NOT classy, and don't make your car look nice, no matter what that kid in the Civic told you.
white3ch0c0late is offline   Reply With Quote
