Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - 2.0L 3ZR-FE for the new Corolla?
View Single Post
Old 02-23-2007, 09:28 AM   #10 (permalink)
silver04rollas
Moderator
Gameroom cash: $570837
View silver04rollas's Photo Gallery
Originally Posted by Bugmenot
Regular vvt-i doesn't have lift. With stepless, you can have a seamless "lift" at any rpm you want not like VVTL-i where you can only have lift at higher rpms and also you get valve variations in vvt-i for fuel economy. It's more like a mix of all the vvt technologies into one, but more efficient.
That is incorrect. VVT-i in any form deals ONLY with variable cam phasing. There is no variable exhaust and intake cam lift (through multiple cam switch overs) in Dual VVT-i or VVT-i regardless of rpm.
To clear difference among each, this is the simplest definition of each:
VVT-i has variable valve timing only on intake valves (accomplished through constant cam phasing).
Dual VVT-i has variable valve timing on both intake and exhaust valves (accomplished through constant cam phasing of both intake/exhaust).
VVTL-i has variable valve timing only on intake valves + variable cam lift on both intake and exhaust cams.
SSM 05 Corolla XRS 6 Spd VVTL-i 2ZZ-GE /04 Corolla S 1ZZ-FE (sold)
BT: 14.67@96mph(I/E)/Injen Cold Air Intake/Greddy SP2/MT90/GPS Navi/Continental ExtremeContact 205/50/16 track radials/Megan Racing/Koni fully adjustable suspension/Cross drilled + slotted rotors/Carbon ceramic pads/Motegi lightweight rims.
"LFA - Passion, soul and character in its purest form"
silver04rollas is offline   Reply With Quote
