Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - 2002 toyota sequoia turns off when in gear
View Single Post
Old 02-27-2007, 07:58 PM   #10 (permalink)
jeffhall
View jeffhall's Photo Gallery
You may be no expert but you know a whole lot more about it than I do. I have an appointment with the dealer this Friday. Tonight I went out and started the Sequoia. It started right up. I let it run for a minute and put it into drive. It stalled immediately. Then I started it and hit the 4 wheel drive button and put it into drive. It stalled immediately. Then I played with the High-Low 4 Wheel drive shifter and whatever was binding freed up. I drove it around the block and it seemed fine. One of the things you said was that it may have something to do with the 4 wheel drive engagement system. I think you are right. I'm not sure what the problem is but that is where I plan on telling the dealer to look. I expect it to lock up again but I don't have any idea when. If you think of anything else I would sure appreciate your advise. Thanks again, I'll let you know what the dealer says after I pick it up.
jeffhall is offline   Reply With Quote
