Originally Posted by darksol
Alright, the dipstick for ATF shows empty. But I can't find the fluid reservoir in the engine bay. Where does it go and do I need to refill all 4 quarts that I drained yesterday?
You add ATF by pouring it down the trans. dipstick tube. Make sure you check ATF level w/ the engine RUNNING, after you've cycled the shift lever from Park - all the way down to 2, and back up to Park. check the marks on the dipstick. There should be a cold fill, and hot fill mark.
Also very important - you'll need to drain the engine oil ASAP since it has been grossly overfilled. Again, check the dipstick for proper levels.
Welcome to TN.
