Originally Posted by CLIFFJONES
Lets see, hmmm how should I put this. Well, first its a good read. 2nd, another reason alot of people buy domestic trucks is b/c of one thing, you can mod them, from tuners, to cams,heads, blocks, and so one. AS of right now there's nothing but exhaust and c/a kits for any of them. Of coarse you can get accessory stuff like the floor mats and ventvisors. ANd then you have the truck accessories as well.
This going to sound a bit strange. Domestic cars better to tune because the engines has allot of unused potential. Tolerances are also bigger on domestic engines because they are most of the time low-tech compered to Japanese designed engines. Tuners don't like high-tech complex engines because it takes a lot more time (and money) to develop and test a performance-kit. And most of the times these performance-kits are not healty for the lifespan of your engine.
Even performance-kits offered by Toyota themself (TRD & TTE) are not 100%. A friend had a Toyota Yaris with a compressor kit from TTE and the engine died with a loud bang (pistonrod left the engineblock). Squising another 10HP out of an Toyota engine and give it a lifespan more then another 10k is hard en expensive. Only a hand full of Toyota engines are good for tuning (4A-G(Z)E, 3S-G(T)E, 1JZ-G(T)E, 2JZ-G(T)E, 1G-G(T/Z)E.
Because the domestic marktet still uses big strong (iron-block) engines, it is no problem to strap an aftermarket compressor or turbocharger on it. They can handle it. But a Japanes engines with low-tolerances will break if you try that. You have to change the pistonrods, crankshaft, valves etc to prevent the engine to break down very fast.
