03-21-2007, 02:14 PM
#15 (permalink)
Here and there...
Originally Posted by Brandon402
I see where you're going with this. But again, im not refering to the DVD itself, Im refering to the drive. The part inside the drive that spins the dvd sees just as many RPMS as a hard drive. Granted, the HD is normally used more than the DVD drive and yes the HD (due to how much more it is used when compared to a DVD drive) will see more useage. But, I dont think the difference in useage is enough to use that as an argument concerning wear and tear. Especially considering where we're at, technology wise, when it comes to HDs.
I can say this though, ive replaced more CDR/W drives and DVD drives than I have HDs.
The way I see though, is even if he chose the DVD driven GPS system. That DVD drive will be spinning just as much as an HD would be when it needs to access the info on the disk. I think, when comparing wear and tear of moving parts, they are both on the same level of risk. Just my opinion though.
You have a good point. Let's hope the newer technology keeps the HD last longer.
