Toyota Nation Forum : Toyota Car and Truck Forums - View Single Post - DIY: OEM Cruise Control
View Single Post
Old 03-26-2007, 11:44 AM   #10 (permalink)
mhadden
Precision driver
mhadden's Avatar
View mhadden's Photo Gallery
Originally Posted by ynnek63
OK...I installed the "crap aftermarket" cruise control I have been very happy with it. It works great. But, I do like the OEM look of this setup, so do you know if the clutch switch from my aftermarket unit can be used with this one. That clutch switch is a PITA to install and I'd rather not have to do it again.
Thanks,
Ken
I think it'll all depend. Ultimately, yes, you should be able to use it because a switch just cuts (or sends) power to indicate that the clutch is depressed. If you can look up into the wiring harness where the clutch switch is located, you'll see the pic that I posted that is the stock switch connector. If your connector is not like this, you can still use your current one, you'll just have to splice wires and reconnect them. If you need any other help, let me know.
2011 Fit Sport 5MT
2011 Pilot EX-L AWD
2008 Goldwing Navi
mhadden is offline   Reply With Quote
