3sge Rwd Conversion - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-05-2005, 04:07 AM   #1 (permalink)
FAB
View FAB's Photo Gallery
3rd Generation 3sge Rwd Conversion
I have a 3sge out of a st204 which I want to use in a rear wheel drive conversion, the gear box I want to use is a five speed out of a 1982 celica which had a r21 engine.
The gearbox is and alloy case type. Does anyone know what toyota bellhousing I can use to marry the 3sge to this gearbox ?
FAB is offline   Reply With Quote
Old 10-05-2005, 09:24 AM   #2 (permalink)
Alltrack Wannabe
View alltracman78's Photo Gallery
a custom one....
alltracman78 is offline   Reply With Quote
Old 10-05-2005, 07:22 PM   #3 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
do an internet search on 3sge
Old 10-06-2005, 02:58 AM   #4 (permalink)
FAB
3rd Generation
Originally Posted by alltracman78
a custom one....
I'm putting them in a 81 RA40 celica, mounts and electronics are all sorted, I just need a bellhousing that will marry this W55 transmission to the 3S block.
Old 10-06-2005, 06:24 AM   #5 (permalink)
SCCA Tech Services
Hotwheelharmer's Avatar
View Hotwheelharmer's Photo Gallery
There is a kit somewhere do do this conversion and even has a bell housing for a W series tranny you just have to do some searching on the internet for the kit. Also if you havce an 81 celica then yo don't have a 3rd gen celica you have a 2nd gen celica. 3rd gens where from 82-85 and where chassic code RA60, RA64 or RA65 The RA40 is a 2nd gen so that little third gen tab you have on the thread should be changed to a second gen for your information.
Brian Harmer
SCCA Solo Technical Assistant
Solo National Rules: http://www.scca.com/documents/Solo%2...lo_Rules_2.pdf
FastTrack: http://www.scca.com/contentpage.aspx?content=78
Hotwheelharmer is offline   Reply With Quote
Old 10-09-2005, 03:46 AM   #6 (permalink)
FAB
I done some searching and toysport sell the bellhousing I need, so thanks for the tip.
As for the GEN3 icon, I picked it because of the engine I'm using. (3SGE OUT OF ST204, THIRD GENERATION, FIRST OF SHIM UNDER BUCKET TYPE.)
