7afe rebuild 94 celica - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-10-2005, 09:42 PM   #1 (permalink)
View badger's Photo Gallery
Tore apart my motor today and found a couple of spun bearings. If anyone has any advice on rebuilding this motor it would really be apreciated. My plans were to go .040 over pistons. Port and polish the head and intake.
badger is offline   Reply With Quote
Old 10-10-2005, 11:30 PM   #2 (permalink)
The Mad Scientist
View Dr Tweak's Photo Gallery
You'll need to have the crank ground and polished because it's probably messed up, you'll need oversize rod bearings assuming those are the ones that spun, and new rods. If you spun a main bearing, you'll also have to have some machine work done to the block, if that's even doable.
On the other hand, it would cost around $300 to pick up a decent low mileage 7AFE and just drop it in.
-Doc
-Dr Tweak, Toyota engine swap wiring expert extraordinaire
Check out some of the swaps I've done at http://www.phoenixtuning.com/swaps.html
Dr Tweak is offline   Reply With Quote
Old 10-12-2005, 10:47 PM   #3 (permalink)
Called machine shop today and its about 400bucks for the crank and block work to be done. This is a spare motor for me. When I got this car I swapped motors right away. Thanks for the info. Know any way to get more HP out of 1.8 rebuilt?
Old 10-15-2005, 05:33 AM   #4 (permalink)
The Mad Scientist
Yeah, don't put another 1.8 in
