hesitation problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 10-16-2005, 07:36 PM   #1 (permalink)
View littlec's Photo Gallery
Canada hesitation problem
first time posting here - tried a couple other sites, not very helpful.
Have a 90 Celica 2.2L - very recently, my car has started to hesitate during acceleration. At first, it was very slight, thought I was imagining it, but has gotten progressively worse over last 2 weeks. I added gas treatment and injector cleaner, no help. brother had a quick look- tried gas line antifreeze if any water, check plugs, distributor, TP sensor - running worse than ever. Any suggestions, before I spend lots of $?
littlec is offline   Reply With Quote
Old 10-17-2005, 02:07 PM   #2 (permalink)
View camry300's Photo Gallery
is there any exhaust leak at the manifold.
camry300 is offline   Reply With Quote
Old 10-18-2005, 05:46 PM   #3 (permalink)
View 360yang's Photo Gallery
same here, i have a start up hesistation problem.. the engine hesistate for a few seconds before it runs properly, and if i dont step on the gas peddle a few times, the start up will eventually die. anyone knows what can be the cause of this?
360yang is offline   Reply With Quote
Old 10-18-2005, 07:51 PM   #4 (permalink)
No, there doesn't appear to be.
Old 10-18-2005, 08:08 PM   #5 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
i bet his coil is going bad?
Old 10-19-2005, 11:51 AM   #6 (permalink)
gts all motor.. hopefully
View 5thGENcelicagts's Photo Gallery
does it sound like shit? because mines used to do that and it sounded almost like a muscle car lol.. but it would really lag on acceleration.. so i took it to my dads friend and he said it was my distributor cap and sure enough after i replaced it it went back to normal
5thGENcelicagts is offline   Reply With Quote
Old 10-19-2005, 05:49 PM   #7 (permalink)
sounds OK - checked distributor, not that. wish it was that easy.
Old 10-19-2005, 05:50 PM   #8 (permalink)
well check that out - thanks
Old 02-02-2006, 05:54 PM   #9 (permalink)
problem solved
Thanks to anyone who responded to my question. A couple of you had a similar problem. My problem turned out to be a simple fix - needed new cap, rotor, wire and plugs, althought the dealership told me you shouldn't use aftermarkets - you'll end up with the same problem. Cost, about $290 (170parts, 120labour) + taxes. Drives like a dream! Good luck!
Old 02-05-2006, 11:56 PM   #10 (permalink)
jimwww's Avatar
View jimwww's Photo Gallery
I have the same thing I think as well..
Odd but in any gear above 1st at about 2800 rpm - 3000rpm there is hesitation - noticible.. and above 3100 - pulls strong after that..
Any ideas? (I did buy the dist cap and rotor and plugs - have not installed yet..)
1995 4runner, V6, 4wd, 5spd, 31x10.5 A/T's
jimwww is offline   Reply With Quote
Old 02-12-2006, 08:29 AM   #11 (permalink)
Another possibility maybe that you need a fuel injector flush and air filter change - changing the rotor/distrib/etc on my completely stopped the hesitation, but I still have a problem with mileage, so the flush will be my next step. Good luck!
Old 02-12-2006, 10:44 PM   #12 (permalink)
jimwww's Avatar
I will try that.. also I am going to change the spark plug wires
Old 02-24-2006, 12:06 PM   #13 (permalink)
jimwww's Avatar
Found the problem - fuel filter had not been changed!
Runs fine now..
