^ no that is not true
yes if the impedence is correct you are good in that department - that is a universal fact - but sometimes the injector has a different size tip that goes into the block - i had that problem on my injectors when they were supposed to be installed on my camry 5sfte... they were some 550's, but they had a gm style end which had been machined, and they were too small for the block so gas would shoot out everywhere...
RC engineering also sells a bunch of sizes, that can fit the 5s, but another factor that may change would be cutting the old clips and splicing new ones in
Lick first... ask questions later
