5sfe turbo question - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-01-2005, 11:59 AM   #1 (permalink)
View klone1000's Photo Gallery
5sfe turbo question
been trying to buy a 3sgte map for months. dont wants pay 300.00 for one. Is they another type of map sensor that will work with the 5sfte????????
klone1000 is offline   Reply With Quote
Old 11-02-2005, 12:30 AM   #2 (permalink)
The Mad Scientist
View Dr Tweak's Photo Gallery
You don't even need a map sensor if you use an FMU. What kind of engine management are you using?
Did you put a WTB ad on the celica and mr2 forums? I've seen them go for around $50.
-Dr Tweak, Toyota engine swap wiring expert extraordinaire
Check out some of the swaps I've done at http://www.phoenixtuning.com/swaps.html
Dr Tweak is offline   Reply With Quote
Old 11-02-2005, 08:54 AM   #3 (permalink)
View locker's Photo Gallery
Dr. Tweak is right you should be able to find one fairly easily if you put up some posts on celica and MR2 forms. They go from anywhere between 50-100... good luck
locker is offline   Reply With Quote
Old 11-06-2005, 08:55 AM   #4 (permalink)
i am using the apexi safc II and the msd btm to control the engine. I need a map sensor but cant find one....... Anyone has one for sale????????????[IMG] [/IMG]
Old 11-06-2005, 09:33 AM   #5 (permalink)
with that set up you could easily run a gm map sensor... I think
Old 11-06-2005, 10:50 AM   #6 (permalink)
So a gm 3 bar map would work with the stock 5sfe computer? Cool seen some of those on ebay foe cheap. Can someone elese back me up on this before I a gm 3 bar map???????
Old 11-06-2005, 12:33 PM   #7 (permalink)
I could be completely wrong... but you have some engine management...
the 2 bars aren't really had to come by though..
Old 11-09-2005, 10:15 PM   #8 (permalink)
3sgte map sensor voltage readings........ I finally found out that it will work.
Pressure Reading------ Voltage------ Throttle %
Idle Vac------------------ 1.4v---------- 26
Zero Vac/Boost--------- 2.5v---------- 65
7 psi---------------------- 3.45v-------- 90
9 psi---------------------- 3.7v---------- 100*
MSD-2312
GM 2 bar Map Sensor I will be using a btm with an apexi safc II. I think it will work!!!!!!!!!!
They all share a common pinout, although the connector keying may be different:
Pin A -- Ground
Pin B -- Sensor output
Pin C -- +5 volts
Manifold Pressure
(relative sea level / absolute)
2 Bar
MAP Output
14.31psi / 29.01psi
4.90V
14.00psi / 28.70psi
4.84V
13.00psi / 27.70psi
4.67V
12.00psi / 26.70psi
4.50V
11.00psi / 25.70psi
4.33V
10.00psi / 24.70psi
4.16V
9.00psi / 23.70psi
3.99V
8.00psi / 22.70psi
3.82V
6.00psi / 20.70psi
3.47V
4.00psi / 18.70psi
3.13V
2.00psi / 16.70psi
2.79V
0.00psi / 14.70psi
2.45V
5.00inHg / 12.24psi
2.03V
10.00inHg / 9.78psi
1.61V
15.00inHg / 7.33psi
1.19V
20.00inHg / 4.87psi
0.77V
25.00inHg / 2.41psi
0.35V
29.10inHg / 0.40psi
0.02V
Old 11-12-2005, 10:10 AM   #9 (permalink)
Got2turbo
epinasty's Avatar
View epinasty's Photo Gallery
That is great news.
I am getting desperate too. Post if you
get a gm sensor working on your 5sfte
epinasty is offline   Reply With Quote
Old 12-04-2005, 02:25 PM   #10 (permalink)
I have my car back on the road now but still dont have the turbo on yet. I ordered a manifold from ebay and had a wastegate flange welded on one of the runners but when I bolted it to my head it was in the way of my hood. That sucks. Then I found a factory 3sgte manifold 1 month later. The guy took another month to mail it... Then I found a ct-26/t3 flange with a wastegate port on ebay. Just got my manifold yesterday a matter of fact.... Maybe next week I will be boosting....
Old 12-06-2005, 12:04 PM   #11 (permalink)
what manifold did you get?
I got an ebay manifold as well and not all the welds were complete. check it over carefully
