Well, it wont start again!!!!!!!1 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-02-2005, 07:48 PM   #1 (permalink)
View Jspafford's Photo Gallery
First of all this car is about to drive me nucking futs! Put in a new battery and it worked fine 3 times this weekend we drove it.
When it first started if you put a load on the electrical system the motor would bog down until you revved it up.. Striked ne as odd, but what the hell do I know?
Went out tonight to start it and it does the same ole crank forever, but this time if you turn the key to On and listen you can hear a steady ticking from under the hood seems to be on the passenger side. WTF?
ANy ideas?
Jspafford is offline   Reply With Quote
Old 11-06-2005, 06:07 PM   #2 (permalink)
thousand_five's Avatar
View thousand_five's Photo Gallery
It's your altenator. It's working partly when it turns faster. It's not charging your battery.
Other posibility is a short on the left side so when you have more amperage it overrides the short. Well that's my two cents.
thousand_five is offline   Reply With Quote
Old 11-06-2005, 07:03 PM   #3 (permalink)
View locker's Photo Gallery
The ticking could be your starter ***edit: if it cranks it aint the starter
locker is offline   Reply With Quote
Old 11-06-2005, 07:54 PM   #4 (permalink)
The Mad Scientist
View Dr Tweak's Photo Gallery
So it cranks fine, but won't start?
-Dr Tweak, Toyota engine swap wiring expert extraordinaire
Check out some of the swaps I've done at http://www.phoenixtuning.com/swaps.html
Dr Tweak is offline   Reply With Quote
Old 11-07-2005, 08:55 AM   #5 (permalink)
View maxpower_hd's Photo Gallery
Checking the alternator is pretty easy. Some parts stores will even check it for free but you have to get it there.
Use a multi meter and check the voltage at the battery. It should be 12V or a little more to start. Anything less and it probably won't. Once it is running it should be something more than 12V. Check the manual for the exact voltage but I believe it should be around 14.5 or so.
Good luck.
maxpower_hd is offline   Reply With Quote
Old 11-11-2005, 06:25 AM   #6 (permalink)
View 19Celi87's Photo Gallery
I'm tired so I prob missed it. . .what year and trim?
19Celi87 is offline   Reply With Quote
