Hand brake light - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-11-2002, 11:05 PM   #1 (permalink)
View Ageeguy's Photo Gallery
Hand brake light
I got a 90 celica gt and some where in between 2nd and 3rd gear my handbrake light goes on, but it goes off after a few seconds it usually happens when the RPM's get high, im guessin its a lose wire or something but i also put in some white face gauages not to long ago but i dont know if that would cause this kind of problem. i would appreciate any insight.
Thanks
Aspiring Civic Killer!
Ageeguy is offline   Reply With Quote
Old 11-12-2002, 03:56 PM   #2 (permalink)
View 89celicagtliftback2's Photo Gallery
my 89 gt does that too. dont worry about it. as long as your hand brake works and it doesnt go on when the light does then it aint a problem
89celicagtliftback2 is offline   Reply With Quote
Old 11-19-2002, 03:11 PM   #3 (permalink)
View Consynx's Photo Gallery
my 98 does that as well, and i've asked some people on forums
i came to the idea that it's probably a lose wire
and toyota is Charging me soo much to "check all wiring"
bums...
Consynx is offline   Reply With Quote
Old 11-19-2002, 07:48 PM   #4 (permalink)
im just gonna take out the instument cluster and disconnect the bulb cuz its just an annoyance hopefully that one bulb wont stop it from not passing inspection.
Thanks for your imput
Old 11-20-2002, 11:58 AM   #5 (permalink)
View 89celicaGTliftback's Photo Gallery
hey ageeguy, u go to UC Davis?
89celicaGTliftback is offline   Reply With Quote
Old 11-20-2002, 02:37 PM   #6 (permalink)
naw still in high school
Old 11-20-2002, 04:55 PM   #7 (permalink)
oh, tought maybe cuz "agee" is there mascot
Old 11-26-2002, 06:08 PM   #8 (permalink)
might not want to do that
the light goes on for a reason
one of two reasons:
1: You need new brakes
2: You're low on brake fluid, or something with the fluid. There is a sensor that tells if the fluid is below a pt.
Old 11-28-2002, 09:29 AM   #9 (permalink)
If it was one of those 2 things u listed that could be wrong why wouldnt the light be on all the time or atleast while braking, instead of only kicking in at high rpms and only in 2 and 3rd (gears), and i just got it inspected 1 month ago so i dont think the brakes need to be replaced but ill get the fluid level checked
Old 11-28-2002, 01:15 PM   #10 (permalink)
View david in germany's Photo Gallery
THE CURE FOR THE BREAK LIGHT
when the fluid is just below the full line it comes on with hard exceleration so if you plan on driving the car hard overfill it. as the breaks wear the fluid level goes down and when enough fluid is missing that the light stays on it is time to replace the pads.
David
david in germany is offline   Reply With Quote
Old 11-30-2002, 12:51 PM   #11 (permalink)
Ill go top off the brake fluid, thanks for your help guys.
Old 12-04-2002, 11:13 AM   #12 (permalink)
View Wldmnky16's Photo Gallery
Agee is dumb
Wldmnky16 is offline   Reply With Quote
