What engine in 1990 Celica? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 11-13-2005, 10:41 PM   #1 (permalink)
2001 Camry LE
View Nuke209's Photo Gallery
My friend is going to drop his celica over at my house, so we can take out the motor and give the car to the junk yard (it crashed, but everything in the bay seems fine)
So i was wondering, what kind of engine is it?
He says it's a 4 cylinder
Nuke209 is offline   Reply With Quote
Old 11-14-2005, 07:29 AM   #2 (permalink)
GT-i Crew
lcarocha's Avatar
View lcarocha's Photo Gallery
What trim? 5th Gen Celicas had 3 different engine options depending on the model trim:
ST/ST-X= 4A-FE, 1.6 lts
GT/GT-S = 5S-FE 2.2 lts
Alltrac/GT4 = 3S-GTE 2.0 lts
Luis C.
92 Celica GT-i (ST182)
2nd Gen 3S-GE
Caracas, Venezuela
http://www.cardomain.com/id/luis_c
lcarocha is offline   Reply With Quote
Old 11-14-2005, 11:16 AM   #3 (permalink)
View 90celicaGT-S's Photo Gallery
4afe- 103hp
5sfe- 130hp
3sgte-200hp
just a little more info
90celicaGT-S is offline   Reply With Quote
Old 11-14-2005, 12:00 PM   #4 (permalink)
2001 Camry LE
thanks for the info, I'll know when he brings it by next week...
btw, how easy is it to remove the engine?
any guides? tips?
only time I ever did anything was a civic swap, that was pretty simple
But this time, we're just removing
Old 11-15-2005, 12:47 AM   #5 (permalink)
The Mad Scientist
View Dr Tweak's Photo Gallery
What are you doing with it? I need one.
-Dr Tweak, Toyota engine swap wiring expert extraordinaire
Check out some of the swaps I've done at http://www.phoenixtuning.com/swaps.html
Dr Tweak is offline   Reply With Quote
Old 11-15-2005, 11:23 AM   #6 (permalink)
2001 Camry LE
we were just going to store it or sell off parts or something like that, we dont know yet...but you need an engine?
Old 11-15-2005, 01:10 PM   #7 (permalink)
Moving Forward
View Cyorke's Photo Gallery
If you ahve done a Civic swap then you shouldnt have problems pulling hte Celica engine. Pretty straigh forward.
Disconnect all wiring, drain fluids, pull motor mounts and you should be jsut about there. Yeah I know there is more to it but really pulling an engine is not that big of a project. Now putting it abck and making sure you ahve everything where it goes is another story.
Chris
PLEASE DO NOT GET RID OF THE OLD TN AS WE KNOW IT.
Cyorke is offline   Reply With Quote
Old 11-15-2005, 06:36 PM   #8 (permalink)
View locker's Photo Gallery
the easiest way of removing the engine is from below. Disconnect everything and leave the two side mounts. Have the car on the ground and pull the car off the motor. Pulling it isn't too bad.... just make sure that on your hoist you tranny side has a good 4 inches of slack so it pulls up after the cam side
locker is offline   Reply With Quote
Old 11-22-2005, 10:57 PM   #9 (permalink)
2001 Camry LE
ok, got mostly everything out but it seems the engine wont come out, i think there's a mount somewhere close to the tranny, is that's what's causing it not to come out?
Old 11-23-2005, 01:33 PM   #10 (permalink)
did you remove both cross members? there are two mounts on the cross member one on the cam side of the motor and one on the top of the tranny.
Are you pulling the motor or dropping it?
Old 11-24-2005, 01:10 AM   #11 (permalink)
2001 Camry LE
pulling
Old 11-24-2005, 06:24 AM   #12 (permalink)
sometimes the acutal mounting piece for the rear mount can get caught by your power steering rack. You may want to start by removing that. its 2 14mm bolts
Old 11-25-2005, 01:39 AM   #13 (permalink)
2001 Camry LE
thanks, will try saturday and give update asap
