92 jdm swap help!!!!! - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-28-2005, 03:50 PM   #1 (permalink)
View 92jdm's Photo Gallery
me and a friend swaped a 92 celica with a 1.6 to the jdm 1.6 and when we try and fire it , it runs but rev-hopps like no other?
whats wrong ecu some thing not hooked up? what please help... thank you
92jdm is offline   Reply With Quote
Old 12-28-2005, 04:35 PM   #2 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
View fredk's Photo Gallery
rev-hop?
Old 12-28-2005, 05:42 PM   #3 (permalink)
Bootsing the 165
View Edward_H's Photo Gallery
rev hop? please explain the meaning of this, what happens, and when it happen?
87 Celica GTS (RIP)
88 Celica All-trac (In the Rebuilding stage)
*Update on alltrac rebuild*
change of plans, now sporting a ST185 block with the 165 ECU & WTA IC.
Edward_H is offline   Reply With Quote
Old 12-28-2005, 09:04 PM   #4 (permalink)
Alltrack Wannabe
View alltracman78's Photo Gallery
I would guess it means the rpms are going up and down. :shrug:
Have you checked for vaccum leaks?
alltracman78 is offline   Reply With Quote
Old 12-29-2005, 01:52 PM   #5 (permalink)
yes at idle it hops from 1500 to 3500 or so... where can i get a vacuum diagram
Old 12-29-2005, 02:08 PM   #6 (permalink)
Alltrack Wannabe
You could try here. www.celicatech.com
I dont' have one myself.
To see if you have a leak, with the engine running, spray brake cleaner around anywhere you took apart that has to do with the intake system.
Also, try around the vaccum lines.
Don't use too much, it's not good for the rubber.
Old 12-29-2005, 05:10 PM   #7 (permalink)
JUST RE ENGINEER IT
fredk's Avatar
are you telling us that it runs 3500k without your foot on the gas?
Old 12-30-2005, 10:03 AM   #8 (permalink)
View Project_ST184's Photo Gallery
if it idles at 3500 that is not a good sign.
Project_ST184 is offline   Reply With Quote
Old 12-30-2005, 04:23 PM   #9 (permalink)
Gameroom cash: $147537
Most likely vaccum leak.
Old 12-31-2005, 08:28 PM   #10 (permalink)
View Quyen's Photo Gallery
Try adjusting the TPS sensor.
This happened when I swapped a 3sfe for a genII 3sge. Turned out the throttle position sensor was slightly opened.
Quyen
1976 Celica GT
1987 Celica GT
1989 Celica Turbo AWD
2002 Celica GT
Quyen is offline   Reply With Quote
