Idle problem - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-02-2006, 08:13 PM   #1 (permalink)
View deeps's Photo Gallery
Idle problem
hi guys, my car is actually a toyota corona. It's the ST190, and has the 4sfe engine in it
It's very very similar to the 5sfe, so i'm posting it here.
I've had an idle problem for quiet a while now. The idle is not that bad, but it's still rough. It's idling a tad less than it should be idling, which is why it's rough.
So now during xmas hols i have a load of time to work out what's wrong with it.
So far i've done the following:
Plugs and leads - changed
Fuel and air filter - changed
Water Pump - changed
PCV - checked and cleaned - seemed ok, was shaking etc.
Coolant temp sensor - changed
vacuum lines - checked by spraying throttle body cleaner
Today, i'm going to try and buy a gasket for my throttle body onto the intake manifold, and remove the iacv, to check that.
I read the codes from the diagnostic box, and got code 22, which was my coolant temp switch. I checked that, and found it was melted and dead to buggery, so i changed that, and now that code is gone and hasn't re appeared.
The idle gets even worse when i turn the fan on (not a/c). Sometimes there's a weird 'tick tick' noise at idle, but it's not a lifter type tick, it's some other tick, which is hard to explain.
When i first start the engine, i get pinging/ticking as well, which seems to go away after ~2 or 3 mins.
What else could be wrong?!
deeps is offline   Reply With Quote
Old 01-02-2006, 10:50 PM   #2 (permalink)
thousand_five's Avatar
View thousand_five's Photo Gallery
What year?
ping/ticking may be oil. What oil weight do are you using?
thousand_five is offline   Reply With Quote
Old 01-03-2006, 12:16 AM   #3 (permalink)
it's a 1992 model
Not sure what oil it's got in it atm, it was last serviced by toyota about 500km's ago
Cold start idle problem 4age bubbawing Archived Corolla threads 2 12-15-2005 05:50 AM
IdLE PROBLEM ZIXXER 1st Generation (1995.5–2004) 2 12-07-2005 06:47 AM
how do correct idle problem 1quickmr2 MR2 Forum 2 04-22-2005 07:49 AM
88 Camry - Idle problem after a hard stint JetspeedCamry 1st & 2nd Generation (1983–1986 & 1987-1991) 3 10-24-2004 11:15 AM
Idle problem. Need Help... oreo Archived Corolla threads 5 12-13-2003 05:13 PM
