2000 Celica GTS Belt Tensioner - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-02-2006, 09:56 PM   #1 (permalink)
View cnote5153's Photo Gallery
I recently posted a question concerning my 2000 GTS's idler pulley. After researching things a little, I've learned this is actually referred to as a "Belt Tensioner Assembly" and seems to be a pretty common problem on 2000 GTS models. I found the TSB and this thing looks to be a bear to fix. There's just no room. Has anyone tackled this repair, or can someone give me an idea of what the dealerr cost is to do the repair?
cnote5153 is offline   Reply With Quote
Old 01-02-2006, 10:00 PM   #2 (permalink)
The Mad Scientist
View Dr Tweak's Photo Gallery
I didn't see your other post, but if you mean that the tensioner is hard to get to to adjust, I know what you mean. They're nearly impossible. Maybe if you unbolt all of the engine mounts except for the one on the driver's side, with a jack supporting the engine, and then jack it up a few inches, you may be able to get to it better.
-Doc
-Dr Tweak, Toyota engine swap wiring expert extraordinaire
Check out some of the swaps I've done at http://www.phoenixtuning.com/swaps.html
Dr Tweak is offline   Reply With Quote
Old 01-02-2006, 10:09 PM   #3 (permalink)
Thanks, Doc. I'm afraid this baby is too far gone for adjustment. It's making a metallic squealing noise. I agree with you - after taking a closer look, the only way to get to this assembly is to jack the engine up and take it from there.
noobie runnin a 91 Celica GTS 5thgenGTS Introduce Yourself Here 3 12-13-2007 11:53 PM
Celica GTS wheel and tire packages Import Tire Supporting Vendor Sales 2 09-16-2005 11:16 AM
Where to buy a CAI for my 2000 Celica GTS 6 Spd? rantech Celica Forum 4 06-06-2003 08:09 PM
81 Celica and Timing Belt GregAt99 Celica Forum 3 05-10-2003 12:09 PM
