Yeah there is a ring that makes contact and closes a circuit when you hit the button, I'm assuming you have an airbag wheel that deployed and you didn't bother replacing the wheel? If thats the case then its likely easier to just replace the wheel. Theres a guy by the name of TRD2000 who has the oe airbag wheel out of his MR2 that would fit your Celi, he's had it for a while so make him an offer, he may let it go cheap. I'd just check to make sure that the horn is working by running the positive wire straight from the battery and just touching one of the contacts on the horn itself.
