Fuel in Cylinder(s) after sitting - Page 2 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-12-2006, 03:59 PM   #16 (permalink)
speedyts49's Avatar
View speedyts49's Photo Gallery
Originally Posted by Tercel GTS
Pressure isn't your problem as it's leaking while shut off. My dollar says you have a bad injector or trash stuck in it.
So do you think if I just remove the injectors and blow them out with say some throttle body cleaner or compressed air that would clear it up?
I've elimanated voltage to the injector when not on so its either stuck injector or maybe fuel presure gauge leaking.
Also have a bad oxygen sensor or ECU, I hoping its the sensor$$$$
'08 Super White Corolla S
'96 Tacoma 5 speed 2.4
'03 Kawaski ZRX 1200
speedyts49 is offline   Reply With Quote
Old 01-12-2006, 04:56 PM   #17 (permalink)
N/A bites
Tercel GTS's Avatar
That'd be a possability but I'd prolly seek a couple of used injectors from a salvage yard or somebody on this forum. They aren't hard to swap out and it may save you a pile of money and aggrivation.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 01-12-2006, 05:45 PM   #18 (permalink)
Dude wheres my Yaris ??
View darkus's Photo Gallery
Bad gaskets /rings ?
2007 Yaris for me (Red)
!!!!!!!! Yaris 4 life !!!!!!!!
darkus is offline   Reply With Quote
Old 01-13-2006, 03:31 AM   #19 (permalink)
Cressida nut
Gameroom cash: $251045
View kamesama980's Photo Gallery
another possibility is that they botched something cleaning them and reassembling them. after all when it comes down to it they are only human. noone is above making errors.
'90 Cressida, 7M-GE, M5 (2JZGE-T coming)
'91 Toyota Pickup, 22R-E, M5
'90 Suzuki VX800
"You don't get to judge me for how I fix what you break"
kamesama980 is offline   Reply With Quote
Old 01-16-2006, 07:11 AM   #20 (permalink)
speedyts49's Avatar
code 26
code 26, rich condition engine light has not come back on since I reset it.
The car is running fine except I probably still have a leaky injector like you all said but I have been driving it everyday so it burns off right away.
Now my idle is still at about 1100 instead of the 800 it should be. Crazy car. I wonder if changing the oxygen sensor will affect that. It did show it was not working in a recent test.
2001 Corolla Starting problem - Fuel Filter theguy 8th Generation (1998-2002) 6 12-31-2008 10:42 PM
Installing fuel pressure regulator 97camryman Camry & Solara Lounge 4 09-14-2005 07:55 PM
Repairing Fuel Line drugal Camry & Solara Lounge 1 09-24-2004 02:38 AM
