Fuel in Cylinder(s) after sitting - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-10-2006, 08:13 PM   #1 (permalink)
speedyts49's Avatar
View speedyts49's Photo Gallery
I recently let my car sit for 5 days and when I tryed to start it it was hydrolocked with gas. Somehow gas had continued to flow into the cylinder after parking it. It wa running great although I had had a code 26 which is rich fuel condition. By hydrolocked I mean it just made a big clunk when i tried to start it. The engine would not turn over.
Any thoughts on why fuel would continue to leak into the cylinder(s). I recently had my injectors cleaned, tested and rebuilt so I really don't think it is the injectors themselves.
An other symtom has been hard starting since we got the car.
'08 Super White Corolla S
'96 Tacoma 5 speed 2.4
'03 Kawaski ZRX 1200
speedyts49 is offline   Reply With Quote
Old 01-10-2006, 09:23 PM   #2 (permalink)
N/A bites
Tercel GTS's Avatar
For some reason you do have an injector leaking. Was only 1 cylinder fueled up or were they all? If only one this will tell you which injector to check. Also check that the injector isn't getting a signal while in off position.
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 01-10-2006, 10:22 PM   #3 (permalink)
speedyts49's Avatar
How would I check to see if it was getting a signal while in the off position? I really think this problem has been here since we bought the car but I have not been able to isolate it.
Old 01-10-2006, 10:30 PM   #4 (permalink)
N/A bites
Tercel GTS's Avatar
Unplug the injectors that leaked and probe the wires with a digital voltage meter. Tell us if it reads any voltage. Check all four plugs.
I'm expecting the injectors may have trash holding them open or they are just leaking. Can't rule out the signal until you check the wires though.
雄のハヤブサ
Old 01-10-2006, 11:04 PM   #5 (permalink)
speedyts49's Avatar
I had the injectors cleaned and I don't think it is them. The wires leading to them is another story.
Will do on checking the voltage on the wires.
Whatever is wrong is a ongoing problem that has got worse as time goes on.
First is was;
hard starting after the engine was warm
then hards starting everytime
now just too much gas flowing even when off.
Old 01-10-2006, 11:14 PM   #6 (permalink)
Alltrack Wannabe
View alltracman78's Photo Gallery
Have you checked the cold start inj?
alltracman78 is offline   Reply With Quote
Old 01-10-2006, 11:37 PM   #7 (permalink)
speedyts49's Avatar
Yeah I did using the voltmeter. I have replaced most of the emision stuff.
Old 01-11-2006, 06:48 AM   #8 (permalink)
Alltrack Wannabe
I mean have you checked to see if it drips.
It is allowed a bit, maybe 1 drop a min or such. I forget off the top of my head.
Old 01-11-2006, 04:38 PM   #9 (permalink)
speedyts49's Avatar
I checked the resistance and it was in spec at 3.5 ohms.
When I unscrewed the banjo bolt gas came out for a couple of seconds then quit. THis was with the power off.
Old 01-11-2006, 04:40 PM   #10 (permalink)
speedyts49's Avatar
The the wire leading to the leaky one did not show any voltage with the power off. The injector itself was within spec for resistance.
Old 01-11-2006, 05:27 PM   #11 (permalink)
Let me out of my cage....
HATEnFATE's Avatar
Gameroom cash: $159350
View HATEnFATE's Photo Gallery
Maybe one of your injectors is reading ok but when the pressure is left in the system, aftrer shutting off the vehicle, fuel is being forced through and leaking into your cylinders. It's just a possible scenerio.
"Fools", said I, "You do not know, silence like a cancer grows.
Hear my words that I might teach you. Take my arms that I might reach you"
But my words, like silent raindrops fell, and echoed, in the wells of silence.....
Jason Johnston
Toyota/Scion of Des Moines
(800)342-7045
HATEnFATE is offline   Reply With Quote
Old 01-11-2006, 06:00 PM   #12 (permalink)
speedyts49's Avatar
Could be that for sure.
I am going to get a fuel pressure gage and see if the fuel pump is pumping too much pressure.
Old 01-11-2006, 07:34 PM   #13 (permalink)
N/A bites
Tercel GTS's Avatar
Pressure isn't your problem as it's leaking while shut off. My dollar says you have a bad injector or trash stuck in it.
雄のハヤブサ
Old 01-11-2006, 10:02 PM   #14 (permalink)
BrightTundra04's Avatar
View BrightTundra04's Photo Gallery
USA
I'll put a dollar on trash in the injectors as well do you have the fuel system flushed or just the injectors.. By that i mean did you pull the injectors when you cleaned them or did you flush the system by hooking a pressure cleaner to the fuel rail?? If you pressurized the rail i bet some trash got knocked lose and is holding an injector open..
BrightTundra04 is offline   Reply With Quote
Old 01-11-2006, 10:45 PM   #15 (permalink)
speedyts49's Avatar
I sent them to http://www.witchhunter.com/
Still you all could be right. I hate to have to pull the darn things again but I may have to.
I still have a bad oxygen sensor accorting to the tests I did today.
http://www.toyotanation.com/forum/t116303.html
2001 Corolla Starting problem - Fuel Filter theguy 8th Generation (1998-2002) 6 12-31-2008 11:42 PM
Installing fuel pressure regulator 97camryman Camry & Solara Lounge 4 09-14-2005 08:55 PM
Repairing Fuel Line drugal Camry & Solara Lounge 1 09-24-2004 03:38 AM
