Code 26 - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-11-2006, 07:54 PM   #1 (permalink)
speedyts49's Avatar
View speedyts49's Photo Gallery
Code 26
I have a code 26 rich condition.
I have been going through the recommended trouble causes as I can.
I just did one to check the main oxygen sensor where you warm your car at 2500 rpm's and then check the voltage flucuations for 10 seconds between the e1 and te1. If you get more or less than eight flucuations it means something but I got zero. I think that means replace the oxygen sensor but does anyone know for sure?
If you replace the sensor and still get zero you have to replace the ECU. At least that is how I understand it.
Also there is a voltage check between the vf1 and e1 where if it reads over zero to replace the oxygen sensor.
Looks like I will be replacing the sensor.
'08 Super White Corolla S
'96 Tacoma 5 speed 2.4
'03 Kawaski ZRX 1200
speedyts49 is offline   Reply With Quote
Old 02-27-2006, 03:22 PM   #2 (permalink)
View CELICAGTS24's Photo Gallery
E1 And Te1 Terminals Are Used For Diagnostic Purposes Only,you Cant Check The Oxygen Sensor Useing These Terminals,to Check The Oxygen Sensor You Need An Occiliscope,or Take Out The Oxygen Sensor Find The Signal And Earth Wiring,useing A Volt Meter Put The Sensor Tip Into Direct Flame,this Should Make The Oxygen Sensor Produce From 0.8-1.1 Volts, If Its Not In That Range Throw It In The Bin
CELICAGTS24 is offline   Reply With Quote
2000 Toyota Corolla VE Trouble Code help??? hssaini Archived Corolla threads 3 07-28-2006 11:02 PM
why am i getting code 52 eyz closd MR2 Forum 7 01-10-2006 09:36 AM
Camry Color Code Confusion jck91camry Camry & Solara Lounge 7 06-22-2004 01:19 AM
Check Engine light Code 25 & 26, please HELP!! xaznxeclipsex MR2 Forum 0 06-01-2004 09:46 PM
ecu trouble code Nx2k Archived Corolla threads 1 02-12-2003 07:36 PM
