84 GT motor missing bad - Toyota Nation Forum : Toyota Car and Truck Forums
Old 12-17-2002, 01:19 AM   #1 (permalink)
homebuilt turbo guru
View 2001rolla's Photo Gallery
I have a 1984 Celica GT that hads started Missing when I start the car up.
It starts great then a few seconds later it starts missing like a cylender
is not firing.
When the car runs for a bit and warms up, it starts running better and the
miss pretty much disapears.
Can anyone tell me where I should look to solve this problem? I have already
checked the wires, plugs, cap, rotor and ignition module so these are not
the sorce of the problem...
http://www.cardomain.com/id/1984gt
2001rolla is offline   Reply With Quote
Old 12-17-2002, 11:59 AM   #2 (permalink)
View Deep's Photo Gallery
Its hard to say without actually looking at it. I'd start with a bottle of gasline antifreeze, its like a buck from NAPA or somwhere. You may have a little condensation in your tank. Let us know if that helps.
Deep is offline   Reply With Quote
Old 12-18-2002, 10:36 PM   #3 (permalink)
View mr_mcfarlane's Photo Gallery
gasoline antifreeze.. better not be freezing in orangecountry..
can you describe the miss a little better? does it idle by itself?
there's acouple different things it could be.. if you're sure it's not the spark, the csi and idle bypass might be acting up..
try to describe it better, and we might be able to walk you through some other checks..
mr_mcfarlane is offline   Reply With Quote
Old 12-18-2002, 10:50 PM   #4 (permalink)
Freezing in Orange County :o ...
The car will run by itself no problem and does not try to die out unless I put into drive but then a tap of the gas gets it back.
I have a remote starter in the car and can hit the button and it starts on its own without a broblem but no more than 20 seconds later it goes into it's slightly rough idle and the missing begins. When I drive the car around a bit and the engine warms up, it starts to purr like a kitten and runs great. I have a slight hesitation when I hit the gas but this has been there for several years and the last time I took her to Toyota they could not help. Reason number one why I don't want to take her to Toyota...
Where is the Idle Bypass located so I can check it out to see if maybe????
Jeff
Old 12-18-2002, 11:00 PM   #5 (permalink)
sounds like the cold idle bypass
it's the thing under the t/b with i think one plug and two hose connects on it..
i can take pics tomorrow if you want..
or do you have a repair manual?
Old 12-18-2002, 11:09 PM   #6 (permalink)
Somewhere I have amanual but will have to look at th one at the Library as I moved and don't know where the manual is.
If you could take a couple pics I would greatly appreciate it.
Thank you,
Jeff
Old 12-19-2002, 08:24 PM   #7 (permalink)
Bah. I always assume that I'm talking to Canadians, sorry about that.
Old 12-20-2002, 07:54 PM   #8 (permalink)
KDM is in
REN69's Avatar
Gameroom cash: $251121
View REN69's Photo Gallery
after all.. this site is canadian isn't it?
Old 12-20-2002, 08:03 PM   #9 (permalink)
What difference does that make??? I was not aware that I had to be in Canada to ask a question on this board about a car that is sold internationally...
Old 01-06-2003, 01:54 PM   #10 (permalink)
There is no substitute.
EKam's Avatar
Gameroom cash: $625265
iTrader Score: 6 reviews
View EKam's Photo Gallery
I think you misunderstood his post. He's trying to say since the site is based in Canada, he assumed most of the people are from Canada.
But that doesn't mean people outside of Canada cannot post here.
18/6/08 - Sayonara Kamuri!
EKam is offline   Reply With Quote
