'00 GTS -Changed Coolant - What Happpened? No Heat & Runs HOT. Air Lock? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-15-2006, 05:44 PM   #1 (permalink)
View 6-Speed's Photo Gallery
USA '00 GTS -Changed Coolant - What Happpened? No Heat & Runs HOT. Air Lock?
This has been easy on every car I've ever owned. Not this one, apparently. I drained the coolant when cold, and followed the under-hood instructions for adding coolant. I have since gone through two heat-cool cycles but have only managed to put in two quarts coolant and 1/2 quart water. Capacity is about 6.3 quarts.
Now the coolant does not seem to be circulating, there is no heat (I figure the heater core is empty) and the engine is running hot.
Do I have "vapor-lock"? Does anyone know what to do next? I'm trying to avoid towing it into the dreaded dealer.
Thanks, Mark
6-Speed is offline   Reply With Quote
Old 01-15-2006, 07:24 PM   #2 (permalink)
thousand_five's Avatar
View thousand_five's Photo Gallery
The cover by the thermostat you need to unscrew the bolt pour coolant till it comes out the hole to get the air out of the lines..... then put the bolt back on.
Hope that helps...
thousand_five is offline   Reply With Quote
Old 01-16-2006, 04:51 PM   #3 (permalink)
Thanks. Although I have not tried this yet, I may not need to, as today on the way into work the heater began working. So far I am on my 5th or 6th heat-cool cycle, and gradually I am getting more coolant in it.
Next time or to anyone else - go to the dealer. This was way too hard - and I was afraid I would blow my head gasket.
Remember when cars were easy to work on?
Old 01-16-2006, 06:37 PM   #4 (permalink)
That Acura Guy
TTercel's Avatar
Gameroom cash: $261315
View TTercel's Photo Gallery
Thumbs down
Cars got way too many computers nowa days and are getting more complicated to work on each year
TTercel is offline   Reply With Quote
Old 01-16-2006, 08:43 PM   #5 (permalink)
Nad1370's Avatar
View Nad1370's Photo Gallery
6 speed,
You have to raise the coolant bottle.
Take the 10mm bolt out that holds the reservoir
There is a place in the bottle where you hook it on top of the hood release latch.
Loosen the cock screw on the bottle while you fill it with coolant. Rev it a few times.
It's a PITA but this is how you should " burp " these 00+ Celica's.
Nad1370 is offline   Reply With Quote
00 celica gts factory air box ia2 Celica Forum 2 08-10-2005 05:06 PM
Turbo the tercel? Flymasta K Tercel, Paseo, Starlet, and Sera Forum 19 01-31-2005 12:38 AM
Ractive Ram Air system. Camry_rider Hardcore Tech and Competition 51 07-23-2004 12:03 PM
