New AIR INTAKE - HELP! Newbie... - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-27-2006, 04:05 PM   #1 (permalink)
View Matsu-Seo's Photo Gallery
Red face New AIR INTAKE - HELP! Newbie...
Hey guys, my bro just got an air intake for his 93' Celica and we just finished installing it. There is a large vacuum noise that comes from the cone filer when the engine is running. Also, he has noticed that he must depress on the accelerator harder in order to get up to higher RPM.
The intake came with a long skinny hose, i wasnt sure if this needed to be hooked up to the air intake system. What is its purpose and how does it work?
Is this normal when with an air intake system(not cold air by the way)? Thanks for any help you can provide us with.
Matsu Nipponese - 98' Toyota SEO - "Never forget who you are, Where your from, and What you own."
Matsu-Seo is offline   Reply With Quote
Old 01-29-2006, 01:22 AM   #2 (permalink)
thousand_five's Avatar
View thousand_five's Photo Gallery
Correct me if I'm wrong but the long skinny hose is a breather hose for the oil.
thousand_five is offline   Reply With Quote
Old 01-29-2006, 05:23 AM   #3 (permalink)
The Other White Meat
terrastrife's Avatar
i belive there shouldnt be a hose before any air metering device, they should all be after the cone.
make sure the breather hose is connected as mentioned. using a mini air filter is a bad idea as that air youre venting has been metered and registered by the ecu. mini breathers on pcv's mess up a/f ratio.
also its probably hot so youre loosing power. typical short ram intake stuff.
terrastrife is offline   Reply With Quote
Old 01-29-2006, 01:20 PM   #4 (permalink)
Old 01-29-2006, 01:59 PM   #5 (permalink)
Thank for the help fellas. I'll have to look into it a bit more.
Question! .:Gen5 Air Intake System:. ModifierMR 5th & 6th Generation (2002-2006 & 2007-2011) 7 10-19-2005 03:01 PM
Turbo the tercel? Flymasta K Tercel, Paseo, Starlet, and Sera Forum 19 01-31-2005 12:38 AM
which air intake should i get? suggestions lessthansane Camry & Solara Lounge 12 12-27-2004 06:33 PM
air intake help isdarco Camry & Solara Lounge 2 10-16-2004 08:49 PM
Planned Air intake Mod... please suggest Audi Man MR2 Forum 10 11-25-2002 11:35 PM
