Pictures of my Tom's wheel installed - Toyota Nation Forum : Toyota Car and Truck Forums
Old 01-29-2006, 04:40 PM   #1 (permalink)
SCCA Tech Services
Hotwheelharmer's Avatar
View Hotwheelharmer's Photo Gallery
Well I ended up ordering a momo hub adaptor for the car. It came in the other day but the holes didn't quite line up so I ended up having to drill bigger holes in the wheel so the hub would line up with the wheel. As you can tell in the close up shot the bolts stick out just a little bit but the main part is what matters. Also please don't mind the mess and the fact there is no carpet or dash. I am currently working on that it will all be back in the car eventually.
Brian Harmer
SCCA Solo Technical Assistant
Solo National Rules: http://www.scca.com/documents/Solo%2...lo_Rules_2.pdf
FastTrack: http://www.scca.com/contentpage.aspx?content=78
Hotwheelharmer is offline   Reply With Quote
new owner problems dack41 2nd Generation (2005+) 17 10-04-2006 11:53 PM
what hub adaptor to use with Tom's Steering wheel Hotwheelharmer Celica Forum 2 01-19-2006 07:06 AM
Front Wheel Drive To Rear Wheel Drive theman33b Camry & Solara Lounge 15 12-15-2005 04:03 AM
How-To: 89+ Non-Airbag Steering Wheel into Pre-89 (MKIII) Jeff Lange Supra Forum 1 10-13-2005 02:17 AM
BAd Experience Beware: GreenBay Tires 86B Feedback: Buyers, Sellers, and Vendors 4 06-08-2004 05:10 PM
