W58 Tranny on a 4AGE - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-08-2006, 02:25 PM   #1 (permalink)
WHAT!!!!
View TeRcElIcA's Photo Gallery
OK... I have a question Will a W58 Transmission work on a 4AGE? I can't seem to find the answer, but I know its known somewhere. I know the T50 will fit, but what about the W58? ... THANKS GUYS!!
TeRcElIcA is offline   Reply With Quote
Old 02-08-2006, 06:35 PM   #2 (permalink)
SCCA Tech Services
Hotwheelharmer's Avatar
View Hotwheelharmer's Photo Gallery
It wont fit with a stock bell housing. However, they do make a bell housing that will bolt up to a W58 and bolts to a 4age. Try club4ag for them being for sale.
Brian Harmer
SCCA Solo Technical Assistant
Solo National Rules: http://www.scca.com/documents/Solo%2...lo_Rules_2.pdf
FastTrack: http://www.scca.com/contentpage.aspx?content=78
Hotwheelharmer is offline   Reply With Quote
Old 02-08-2006, 06:45 PM   #3 (permalink)
WHAT!!!!
How about a T50 Bell housing? I'm getting the T50 transmission with the 4AGE. Should I just stick with those two instead of my w58? Also will my stock driveshaft connect to the T50 Transmission by any chance .
Old 02-08-2006, 07:29 PM   #4 (permalink)
SCCA Tech Services
personally if it were me I would try and find a bell housing to make a W58 work because in my opinion the W trannies are better thenthe T trannies. As for the driveshaft I doubt it but it might. You will probably have to measure and have a driveshaft shop make you a driveshaft.
Brian Harmer
Old 02-08-2006, 07:48 PM   #5 (permalink)
WHAT!!!!
OK OK... Well I'm buying high mileage 4age motor, t50 tranny, intake manifold, harness, ecu, distributor, egr, intake box, injectors and rails. etc. ALL FOR $700. BUT there is 200,000 miles on the engine, which TOYOTA LAST FOREVER... naw.. but I'll probably get another 4age just incase. anyway, After I get that T tranny, I should take the bell housing off and put it on my W58? Make it a TW58? .
Old 02-08-2006, 08:01 PM   #6 (permalink)
SCCA Tech Services
No the bell housing from the T50 will not work on a W58. You have to get a custom made W58-4age bell housing.
Brian Harmer
Old 02-08-2006, 08:02 PM   #7 (permalink)
WHAT!!!!
what if I just custom the Drive shaft instead.. Seems alot easier considering I can weld pretty good.
Old 02-08-2006, 08:08 PM   #8 (permalink)
SCCA Tech Services
Honestly you probably don't want to be making your own custom driveshaft because you probably don't have the ability to balance it. Also you need a custom bellhousing if you want a W58 on your 4age there is no way around it. If you just put the 4age with a T50 then the only thing you need is a custom driveshaft but if you want a W58 you will need a custom bell housing and a custom driveshaft.
Brian Harmer
Old 02-08-2006, 08:09 PM   #9 (permalink)
WHAT!!!!
yeah thats what I meant.. The driveshaft with the t50.
4age 20v tranny Trini Hardcore Tech and Competition 9 10-15-2004 12:13 AM
strongest tranny for 4age????? 20vstarlet Hardcore Tech and Competition 9 02-15-2004 09:45 PM
