need help with heater - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-09-2006, 01:54 PM   #1 (permalink)
View thao's Photo Gallery
i have a 94 celica st. my heater works but only when i step on the gas pedal.
if it's parked, i have to rev my engine to get warm air. if i am at a stop light or stop sign,
the air becomes cold. i thought it was a fuse but it's not. any ideas?
thao is offline   Reply With Quote
Old 02-09-2006, 04:13 PM   #2 (permalink)
Gameroom cash: $103420
View 90celica's Photo Gallery
could be a clogged heater core!
1990 Celica GT - work in progress
1994 Tercel
90celica is offline   Reply With Quote
Old 02-10-2006, 02:43 AM   #3 (permalink)
engineer in training
Gameroom cash: $145055
^ Thats a possibility, or a clogged cooling system, when was the last time you had it flushed? What kind of antifreeze/water mixture are you running, when was the last time you changed your thermostat?
Old 02-10-2006, 06:38 AM   #4 (permalink)
could an improper coolant & water mixture cause this also???
1994 Tercel
Old 02-10-2006, 07:27 AM   #5 (permalink)
i had never changed my coolant yet. maybe i'll try that this weekend. where is the heater core located?
Old 02-10-2006, 09:58 AM   #6 (permalink)
View markpc's Photo Gallery
heater matrix
Your cooling system needs more than just water, the anti-freeze you should put in your cooling system also stops rust from forming inside the the engines internal parts. If the water is a horrible rusty brown drain the system and refill run the engine until it reaches full temp and check it again if it is not clean repeat but DO NOT PUT COLD WATER IN A HOT ENGINE as you can crack the block. If the problem is still there you will have to take out the heater matrix in the dash and either clean it yourself or buy another. Good luck and use anti-feeze. The matrix or heater core is in the middle of the dash and is a tiny radiator so be gentle.
markpc is offline   Reply With Quote
Old 02-10-2006, 06:32 PM   #7 (permalink)
Try the simpler things first, like I said above when was the last time your thermostat was changed? if its stuck open a little bit the engine will run a little too cool and you may not get any heat.
1988 Camry Heater Cycles Between Heat & No Heat lashby 1st & 2nd Generation (1983–1986 & 1987-1991) 30 12-11-2006 02:29 PM
Strange electrical and heater probs. singlecoil Archived Corolla threads 6 02-19-2005 08:33 AM
Heater Output 1998 Camry 4 Cylinder cdlubbe 3rd & 4th Generation (1992–1996 & 1997–2001) 3 01-24-2005 11:18 AM
Heater core kc_jon Supra Forum 1 11-27-2004 11:15 PM
My Gen3's heater sucks! Gen3cruiser 3rd & 4th Generation (1992–1996 & 1997–2001) 35 01-26-2004 11:07 AM
