HELP!! What differential will swap in my 85 Celica?? - Toyota Nation Forum : Toyota Car and Truck Forums
Old 02-14-2006, 11:43 PM   #1 (permalink)
View toyloco's Photo Gallery
Question HELP!! What differential will swap in my 85 Celica??
I bought an 85 Celica ST and the Differential is froze up..
Here is the Data plate info.
C/TR A/TM 148 - YF 26 - T382 - T58
What can I use for a Differential to throw back in the car to make it drive again? I don't care about the ratio as much as this thing has to be able to move.
Can I use like a differential from a 1st gen Celica or late 70's early 80's Corolla??
Basically, what are my options..?? I need to get this thing driving again.
Thanks in advance
toyloco is offline   Reply With Quote
Old 02-16-2006, 07:41 PM   #2 (permalink)
noob Starlet owner
View usdm240's Photo Gallery
you can use a rear diff from the same year Supra. the ratio is slightly different, but it will power your car. i used one temporarily when i blew my diff in my '85 GT.
The Rides:
'93 Nissan 240SX 'vert
'81 Toyota Starlet
-Bruce-
usdm240 is offline   Reply With Quote
Old 02-17-2006, 05:13 PM   #3 (permalink)
Well, I finally was able to pop out the old Differential Center Drop Out Chunk, as I was fighting the Stubborn Passangers side axle that refused to come out until I spent 5 minutes on it with a Slide Hammer.. . I know why It blew up now... No Gear oil...Well I learned a lesson.. Always check that fluid level along with all the other fluids...But I can't believe no one here knows if another Center Differential drop out chunk will swap right back into my car? Sooo.. I guess I will go experiment with the ones at the local wrecking yard to find out the hard way.. Thanks anyway guys..
I think the Supra's were all Independant axles and have a rear cover where mine is a solid axle with a chunk that comes out the front?? Unless you mean one from the Early Supra??
Thanks..
Old 02-17-2006, 06:24 PM   #4 (permalink)
N/A bites
Tercel GTS's Avatar
Check out this rear....
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMEWA%3AIT
雄のハヤブサ
Tercel GTS is offline   Reply With Quote
Old 02-17-2006, 10:19 PM   #5 (permalink)
That looks a lot like mine with the exceptions of mine not having Disc's or LSD. I wouldn't pay that much for a whole rearend when I all I need is a Center part. Thanks though
Old 02-18-2006, 11:35 PM   #6 (permalink)
OK, I managed to get the Center chunk from a 79 Celica GT to drop in to my 85 ST. So I am back in busness.. Just thought if this ever happens to anyone else they can find this post and know what will work if they are in a pinch.
Thanks
89 celica GT engine swap mehret General Discussion 3 08-25-2008 03:58 PM
Celica GT World Challenge Car Engine Swap Advice? turn 7 Hardcore Tech and Competition 9 02-21-2005 11:33 PM
85 Celica Gts convertable cjhansen Celica Forum 4 02-01-2005 02:42 AM
91 celica st eng. swap? HELP W8NLine Celica Forum 18 07-07-2004 05:13 PM
What engines will swap into a 86-89 Celica GTS? 24valvage Celica Forum 4 03-30-2003 12:07 AM
